Error On Transmission Lines
Discussion in 'Feedback and Suggestions' started by Unregistered, Sep 12, 2008.
  1. Unregistered
    Thread Starter Guest
    There is an error on the following page:
    http://www.allaboutcircuits.com/vol_2/chpt_14/7.html
    The phase shift in the graphs are wrong for short versus open circuit.
    When a transmission line is open circuited:
    There is no phase shift in the voltage of the reflected wave (voltages add and increase in magnetude). And for a 1/4 wavelength line, the voltages on the INPUT side always add to zero (but everywhere else on they add to some other number).
    There is a 180 degree shift in the reflected current (currents subtract and increase).
    For a short circuited transmission line:
    There is a 180 degree phase shift in the voltage (voltages add and cancel each other out on the LOAD side (but can add to something else elsewhere), and no phase shift in the current (currents subtract and cancel each other out on the LOAD side (but they can add to something else elsewhere).
  2. Dcrunkilton
    E-book Co-ordinator
    Jul 31, 2004
    416
    11
    Are you refering to the dashed lines in the graphs? The dashed line are the one thing that does not make sense to me. However, I need to do some more research and respond further in about a week.
    The solid lines look OK. But, I need to do more research to be sure to be sure that is really the case.
    Dennis
