I noticed this error in http://www.allaboutcircuits.com/vol_3/chpt_4/1.html
at the same link the diagrams showing the current direction for npn and pnp are wrong. the left most diagram should be npn and rightmost diagram should be pnp. Source:
it should be NPN or PNP respectively.The main current that is controlled goes from collector to emitter, or from emitter to collector, depending on the type of transistor it is (PNP or NPN, respectively).
Microelectronic Circuits, Sedra/Smith, 5th edition, pp.393, figure 5.14
