Error in circuit analysis paper
Discussion in 'Feedback and Suggestions' started by JohnBS, Sep 20, 2015.
  1. JohnBS
    Sep 20, 2015
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    And the errors are due to the stupid "electron current convention" used in the example. They cant keep the signs straight!
  3. JohnBS
    Sep 20, 2015
    yes: perhaps I should have said "The solution shows them +ve" . A cursory glance tells you the "big battery" current will dominate (i.e. conventional flow from +ve to -ve) .
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Tain't gonna change guys. If it doesn't matter as you keep claiming then get over it. Otherwise good luck explaining vacuum tubes and other such devices.
  5. JohnBS
    Sep 20, 2015
    I don't give a fig which "convention" is used: this "educational" article had an error in the solution shown in the section "branch current": it's now been corrected: many thanks.
