Error in capacitors section
Discussion in 'Feedback and Suggestions' started by jut, Dec 27, 2007.
  1. jut
    Thread Starter Senior Member
    Aug 25, 2007
    224
    http://www.allaboutcircuits.com/vol_1/chpt_13/4.html
    The formula for series capacitance has been substituted with a formula for permittivity.
    Since an admin type person will likely respond to this, I'd like to ask another question about the capacitors chapter. Why doesn't the chapter talk about voltage division for capacitors in series, or current division for capacitors in parallel?
    This introduction to capacitors is good explanation. It's interesting to contrast it to an actual textbook.
    Thanks to you guys for an awesome online book.
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    You are indeed correct, not sure why that has happened.
    This is covered in a more appropriate section in Volume II: http://www.allaboutcircuits.com/vol_2/chpt_4/index.html
    Thanks for the comments.
    Dave
  3. exscape
    Jan 19, 2012
    28
    Uh... Bump? Over four years later, and I just ran in to this.
    Also, the picture for calculating the sum of parallel capacitance is a table of the dielectric constants for various materials. :confused:
    Edit: There's another incorrect picture over here: http://www.allaboutcircuits.com/vol_1/chpt_14/3.html :)
    The first picture should be (and is, in the PDF) a table of the different units used for various magnetic quantities in the CGS/SI/English measuring systems.
  4. exscape
    Jan 19, 2012
    28
    There's yet another misplaced picture here (the second one): http://www.allaboutcircuits.com/vol_1/chpt_15/4.html
    Since these errors appear to be quite frequent, is there something in particular wrong with the layout setup? :)
    The PDF is yet again unaffected.
    Edit: The last image there (the second formula) is also incorrect.
