Error "could not find space (200 bytes) for auto/param block"
Discussion in 'Embedded Systems and Microcontrollers' started by ecaits, Apr 6, 2014.
  1. ecaits
    Jan 6, 2014
    52
    Dear All,
    When I compile the program at that time I am getting error like...
    Error [1253] double.c; 55. could not find space (200 bytes) for auto/param block
    Error [1253] C:\Users\NV49C10I\Desktop\Try Code\try.c; 39. could not find space (200 bytes) for auto/param block
    ********** Build failed! **********
    Which type of error is this and why it generate????
  2. ErnieM
    Apr 24, 2011
    7,442
    1,628
    Looks like the output from some C compiler for some unknown computer.
    I would imagine the issue is you are out of memory space for the task you are trying to perform.
    With so little information supplied I can not suggest anything to try.
  3. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    LMGTFY:
    HiTechC FAQ 791
    HiTech Forum
    As ErnieM says, one possibility is that you are flat out of memory.
    Another more or less known issue is that HiTech is sensitive to the banking inherent in 8-bit PICs. Even if you have lots of memory available, if you use more than 256 bytes in one source file you can run into trouble since the compiler uses direct addressing (banked) as a default. All the declarations in one .C file have to fit into one bank.
    The exception is if you use it all at once (a big array of structures for example). when that's the case, the compiler will allocate the RAM in 'bigbss' which uses the FSR to access RAM. This issue is described in the FAQs as well.
    Interesting that the offending filename and line number is the same as that in the forum post.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    The best thing is to show us your code. It could be that you can save some memory by putting constants in ROM as one example
