Error correcting packet protocol source code
Discussion in 'Embedded Systems and Microcontrollers' started by bassplayer142, Oct 17, 2011.
  1. bassplayer142
    Thread Starter Active Member
    Jan 2, 2007
    89
    Does anyone have any recommendations for some free and quick source code for a packet interface. I'm looking for something along the lines of start byte, n-byte length, n-bytes of data, checksum, end byte.
    I want reliable communication that will drop packets and/or not get hung up on code. Faster would be better but if it isn't optimal or doesn't have a checksum (just a start and end byte check) that would be fine. Thanks in advance!
  2. joeyd999
    Jun 6, 2011
    2,756
    2,924
    You may want to research some old zmodem or kermit protocols...there should be lots of source code available online. They may not be exactly what you want, but with minor changes they may do.
    bassplayer142 likes this.
  3. bassplayer142
    Jan 2, 2007
    89
    Thanks! I'll take a look at these for sure.
