Hi All,
i am new user to this framework getting below error.
ERROR 1999: Error in 'ozDriverGSMmodem/OpenComPort': The port 'COM1' does not exist
please assist, Thanks A lot!
hvasamse
That is what is in one of the pictures he posted, it is a USB to TTL module he is trying to connect to the GSM module..... The OP could always look under the device manager, under ports, to see what comm # the OS assigns to the adapter....Do you use a USB to serial converter? In that case the comport alias will most likely not be COM1. However I am only guessing here. I would help if you gave more info about your problem. What kind of software/hardware/OS are you using
by Jake Hertz
by Dale Wilson
by Don Wilcher
by Jake Hertz
