Hey all,
I've got a few 5 kohm potentiometers that I'm messing around with, but their behavior is really strange. If I start at 0 ohms and slowly increase the potentiometer resistance, the resistance goes up just fine until about 100 ohms, then it jumps drastically up to about 1.5 kohm, then increases fine after that. I have a few of these pots and all behave the same way, so I'm pretty sure it's not just a bad pot.
I'm looking at using these in voltage divider circuits to provide analog inputs for various uC projects, but if I'm going to want some sort of precision (I always do ), that jump from 100 to 1000 ohms really bothers me. For example, if I'm creating a voltage divider circuit with an output (across the pot) that sweeps from 0-5V with a 15V input and 10kohm resistor as the other element, my voltage would jump from approximately 0.15V to 1.36V across the potentiometer when the pot is barely turned. Not good enough for me
I'm wondering if there's a way to compensate for this abrupt change and get a more "linear" voltage sweep. I can't think of anything right now besides lookup tables in the uC, but that would require setting the lookup tables for each pot individually. Maybe a resistive voltage divider isn't the way I should be looking at it, but I'm not sure. Any thoughts?
