Equivalent resistance
Discussion in 'Homework Help' started by gicode0823, Feb 19, 2012.
  1. gicode0823
    Feb 8, 2012
    31
    (a) Find equivalent resistance respect to terminals A and B.
    (b) Find equivalent resistance respect to terminal A and C.
    redrew the diagram using iCircuit app
    First I counted the all the node (8 nodes)
    In series:
    31 + 25 = 56Ω
    38 + 29 = 67Ω
    then I redrew the diagram
    parallel:
    67//26//39//23 = 6.65Ω
    26//30 = 13.93Ω
    32//34 = 16.48Ω
    I redrew again
    21 + 6.65 = 27.65
    24//32//27.65 = 9.17
    Now I saw that the 16.48 resistor is shorted
    I redrew again
    27//32 = 14.64
    13.93 // 56 = 11.15
    11.15 + 37 = 48.15
    48.15//14.64//9.17 = 5.04 Ω
    But the answer for part (a) is 13.07Ω.
    I can't seem to find the error in my computation...
  2. steveb
    Jul 3, 2008
    2,433
    469
    It looks like you have a typo in your first schematic. The 34 ohm resistor was written as a 31 ohm resistor. I'm guessing that's not the only mistake, but I'll look further.
  3. steveb
    Jul 3, 2008
    2,433
    469
    The 16.48 ohm resistor shouldn't be shorted.
  4. gicode0823
    Feb 8, 2012
    31
    I understand now that 16.48 ohm resistor shouldnt be shorted... but still not getting the right answer. Will redo this problem again...
  5. gicode0823
    Feb 8, 2012
    31
    31 + 25 = 56
    38 + 29 = 67
    23//36//39//26//67 = 6.65
    26//30 = 13.93
    32//34 = 16.48
    33//27 = 14.85
    R1 = 24
    R2 = 21
    R3 = 6.65
    R4 = 16.48
    R5 = 14.85
    R6 = 37
    R7 = 13.93
    R8 = 56
    R9 = 35
    14.85 + 37 = 51.85
    51.85//13.93 = 10.98
    10.98 + 56 = 66.98
    16.48//66.98 = 13.23
    21 + 6.65 = 27.65
    13.23 + 24 = 37.23
    10.92 as answer.
    Other two tries, I got 53.02550844 ohms...
    Can't find the error...
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Almost correct.
    Rab=24||(13.23+(35||27.65))=13.065Ω
    gicode0823 likes this.
  7. The Electrician
    Oct 9, 2007
    2,300
    335
    It looks to me like Rac is not going to work out so nicely. I think a delta-wye transformation may be necessary. Anyway, for reference, I get Rac = 26.2607
    gicode0823 and t_n_k like this.
