Equivalent Resistance
Discussion in 'Homework Help' started by mwootan, Apr 4, 2010.
  1. mwootan
    Apr 16, 2009
    15
    Did I do this correctly?
    I have a given applied voltage of 208.
    R1= 50Ω, R2= 75Ω, R3= 400Ω (R2 & R3 in parallel), R4= 100Ω, R5= 400Ω (R4 & R5 in parallel), and lastly R6= 175Ω.
    I have figured R2&R3= 63.157 and R4&R5= 80Ω
    I added all together with a total of 368.157Ω
    Rt= 368.157Ω
    It= .565
    Er1= 28.25 volts
    Er2&3= 35.683 volts
    Er4&5= 45.2 volts
    Er6= 98.875 volts
    ( To check I rounded the answers to 28v + 36V + 45V + 99v)
    I then got 208 volts which is my applied voltage.:confused:
  2. PRS
    Aug 24, 2008
    989
    35
    You need to post a schematic.
  3. mwootan
    Apr 16, 2009
    15
    Here's the schematic of my question.
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    Yes, your answer is correct.
    Ar you confused about the answer?
  5. mwootan
    Apr 16, 2009
    15
    I was just unsure of my thinking this out. I understand what I did. Thanks!:)
