The Electrician
- Joined Oct 9, 2007
- 2,970
Because the circuit of this thread has the same topology as a Wheatstone bridge: https://en.wikipedia.org/wiki/Wheatstone_bridgeWhere did the conclusion this is a bridge come from anyway?
It is five unknown resistors. The solution should be in terms of these five unknowns.
The Req seen by the voltage source can't be determined by ordinary parallel and series resistance formulas. This is the simplest circuit that can't be solved with those simple formulas, so it's often given to beginning students to confound them. It is often drawn in such a way as to make it even more tricky, as was done in the example in post #1.
The difficulty is discussed in this Wikipedia article: https://en.wikipedia.org/wiki/Y-Δ_transform
Under the heading "Simplification of networks", it is shown how to use the wye-delta transform to change the network to one where ordinary series and parallel resistor formulas can be used.
