equivalent of max038
Discussion in 'General Electronics Chat' started by matbymay, Jul 29, 2009.
  1. matbymay
    Jul 14, 2009
    27
    it is signal generator sinewave and others. i need that kind of IC however max038 is not manufactured anymore. do you suggest equivalent or different ideas?
    thank you
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    There is the NTE864, which is an equivalent IC. But the price for them has gone up to something like $54.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Futurlec still shows the MAX038CPP available for around $23/ea. Be prepared to pay a hefty shipping charge on top of that, and a wait of at least a month before you get it.
    The output at 20MHz won't be pretty.
    You'd be a lot better off using a crystal oscillator (around $4) in conjunction with a low-pass filter. The low-pass filter could be as simple as a PI filter; a single 820nH inductor with a 160pF cap to ground on either end of it. Choose an Rin and Rt to suit your oscillator.
  4. matbymay
    Jul 14, 2009
    27
    thanks
    using crystall oscilator with lowpass filter is good idea do you have any application for that so i can get idea to implement mine.
