yes..you got my point..so far im using 7495 and full adder...my problem is in the 7495 pin mode,sr, and sl...So now for the real question, what do you mean by an "equivalent logic circuit"? Do you mean a schematic using gates and registers that implements this adder? If so, what work have you done thus far?
This makes no sense. If the output is when I see that there's eight zero's and that's the output, then what purpose does the circuit serve? The output is simply eight zeros.if you see there's eight zero's ..that's the output..
i mean there's the output display...sorry about that..if you see there's eight zero's ..that's the output..
What are you using for the full adder?
Something will always be displayed. How will the person know that what they are seeing is the final result?i mean there's the output display...sorry about that..
You still haven't said what you are using for the 4 bit adder. If I had asked, "What are you using for your shift registers?" You would have said, a 7495. So, what are you using for your 4 bit adder?
I think the OP is using the 74LS283 for the adder. But I dont know what is the single bit thing that labelled as "ADD". Is there such a gate in existence?You still haven't said what you are using for the 4 bit adder. If I had asked, "What are you using for your shift registers?" You would have said, a 7495. So, what are you using for your 4 bit adder?
Thread starter | Similar threads | Forum | Replies | Date |
G | DC equivalent circuit for selective amplifier | Homework Help | 4 | |
Moset equivalent | Technical Repair | 3 | ||
TLIN (ADS) equivalent model in CADENCE VIRTUOSO | Analog & Mixed-Signal Design | 0 | ||
S | Logic gate relay equivalent | Digital Design | 10 | |
0 | logic gate equivalent circuit of a bosch relay? | Digital Design | 7 |
by Aaron Carman
by Aaron Carman
by Jake Hertz
