Equivalent input capacitance
Discussion in 'Homework Help' started by psycoadam, Oct 18, 2011.
  1. psycoadam
    Oct 18, 2011
    19
    [​IMG]I am having difficulty with understanding how to solve the circuit with the capacitor tied to the output of the op-amp. I assume that I break the circuit down into two parts and then solve for the Thev. equivalent circuit but with no input voltage I am at a loss. Do I add a source at the output and then open circuit the capacitor and solve the circuit that way?
    any help would be appreciated.
    the problem asks for the equivalent input capacitance Ceq.
  2. crutschow
    Mar 14, 2008
    13,496
    3,373
    The first op amp is a follower/buffer. The second op amp is an inverter with gain. So what effect would this have on the apparent capacitance caused by C at Ceq? Remember C = Q/V.
  3. psycoadam
    Oct 18, 2011
    19
    So if the gain of the follower is one, and the gain of the inverter is R2/R1 that leads me to
    Ceq = C(1+Av)? where Av = R2/R1?
  4. Ron H
    Apr 14, 2005
    7,050
    657
    Close. This is not the same as Miller capacitance.
    EDIT: It is the same as Miller capacitance. A thousand pardons.:(
  5. psycoadam
    Oct 18, 2011
    19
    I guess I am trying to make this harder than it really is. I understand the C=Q/V but what is confusing me is the charge. I thought of using a capacitive divider, but in the end I get a negative value for Ceq because in the problem C = 6nF, R1 = 3.8k, and R2 = 24.8k.
    Vo/Vin = C/(C+Ceq)
    and since Vo/Vin = R2/R1 then
    Ceq = C* (R1-R2)/R2
    Thank you all for your help
  6. Ron H
    Apr 14, 2005
    7,050
    657
    I am very embarrassed.:(
    You were correct in post #3. It is the same as Miller capacitance. I'm sorry for confusing you.
    Carl, I needed you to keep me honest. Where were you?:eek:
  7. crutschow
    Mar 14, 2008
    13,496
    3,373
    Sorry, by the time I saw your post your had already corrected it.:rolleyes:
  8. Ron H
    Apr 14, 2005
    7,050
    657
    OK, you're forgiven. I hope I am also.:(
  9. psycoadam
    Oct 18, 2011
    19
    Thanks guys! I really appreciate all the help! Don't worry, I was just making sure I was not going insane :)
    Miller Capacitance it is!
