equilaterial triangular coil self capacitance
Discussion in 'The Projects Forum' started by pafrazier, Jun 4, 2011.
  1. pafrazier
    Thread Starter Active Member
    Jun 4, 2011
    57
    Can anyone tell me how to calculate self capacitance of an equilateral triangle coil? Or an online calculator that could do that. It would only need to do one turn. There are online calculators for inductance, but could not locate anything for capacitance.
    I posted in another catagory as well. New to forum.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    What does one of these things do? What the the purpose of the triangle shape?
  3. pafrazier
    Jun 4, 2011
    57
    Thanks for responding. I am experimenting with different geometric coils. To see what happens when a charge is applied.
  4. Kermit2
    Feb 5, 2010
    3,854
    968
  5. pafrazier
    Jun 4, 2011
    57
    Thanks Kermit 2 I will check it out.
  6. retched
    Dec 5, 2009
    5,201
    313
    Coilcraft makes "square" coils rather than round and gets much better ratings than a typical round wound... Not to mention smaller footprint.
  7. wayneh
    Sep 9, 2010
    12,405
    3,256
    Isn't the capacitance more a factor of the insulation of the coil wire than the coil itself, and whatever shape it may have? I mean, would an uninsulated triangle of wire have any relevant capacitance?
  8. DickCappels
    Aug 21, 2008
    2,785
    676
    "Isn't the capacitance more a factor of the insulation of the coil wire than the coil itself, and whatever shape it may have?"
    When closely wound, the insulation is very important. When "loosely" wound, such as with basketweave winding, insulation plays a smaller role.
    "...I mean, would an uninsulated triangle of wire have any relevant capacitance"
    That depends on the operative definition of "relevant". If for example, you were to use a single triangular turn of uninsulated wire at 10 cm per side, you would find that is resonates (the inductance and its own capacitance) at some hundreds of MHz.
  9. wayneh
    Sep 9, 2010
    12,405
    3,256
    So, where is the charge stored? Would the capacitance remain in a vacuum (meaning the charge is stored within the conductor itself)?
  10. pafrazier
    Jun 4, 2011
    57
    I am still trying to calc the self cap for equilateral triangle. Thanks Kermit2 for that link. It is over my head. I am a novice.
    Dick have been calc come triangles knowing the resistance and inductance and imputing some cap values and am getting rf in 100's of khz. I am trying to get to the self capactance of the triangle itself.
    Thanks for all your input any more ideas on calc self capacitance?
