Equalization & Ringing for a Square Wave Signal in VLC
Discussion in 'The Projects Forum' started by Boomin Perera, Aug 27, 2015.
  1. Boomin Perera
    Aug 27, 2015
    6
    I am currently working on a VLC project to build a VLC receiver. I attached a schematic of the circuit I have designed. The circuit on the left is the transmitter sending a square signal at 1 MHz using the CREE RGB LED. I am receiving the signal at the other end using a OSRAM photo-diode and passing it through front end amplifier to amplify the received signal. Later its sent through a 1st order equalization circuit, to fix my distorted square wave signal. I am unsure whether my equalization circuit is correct since I do not see any change in the signal when I implement this circuit. I also experience a ringing (overshoot and oscillations to settle down) in the output waveform. Could you please help me understand the how I can equalize to get a better response to get a cleaner square wave and also to reduce the ringing in my circuit. Any response is much appreciated. Let me know if you need any more information.
  2. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,676
    1,294
    1. What is VLC?
    2. Are you trying to recover the 1 MHz squarewave, of just detect that it is present?
    3. The LED in the transmitter is in backwards.
    4. Why use an RGB LED? Photodiodes respond to a narrow range of wavelengths.
    5. Photodiode amplifiers usually run the diode as a current source driving the inverting input of the opamp. Search "photodiode amplifier circuit" for many examples.
    6. Ringing in high speed circuits usually is due to grounding issues, like long leads or narrow traces. Also, it could be coming from the scope ground connection. On many scope probes the ground lead is 3 or 4 inches long and acts like a loop antenna.
    ak
  3. Boomin Perera
    Aug 27, 2015
    6
    @Analog Kid -Thanks for the reply much appreciated.
    1. Visible Light Communication
    2. I am trying to recover it back
    2. Sorry about that , its incorrect in the schematic
    4. My project has been specified to using RGB LEDs (helps in WDM)
    5. Thank you ill check on that , but in the design that part of the circuit works
    6. I will look into that , thank you very much
    Would you happen to know any analog circuits regarding channel equalization (to recover the square signal not been distorted)
  4. Brevor
    Apr 9, 2011
    282
    56
    What is WDM? You need to stop using abrieviations.
  5. ronv
    Nov 12, 2008
    3,391
    1,446
    If your diodes are fast you shouldn't need any "equalization". You might try adding 50 ohms from the output to ground.
    Do you have the circuit on a board with ground plane?
    Good power supply decoupling?
    Maybe a scope picture?
  6. DickCappels
    Aug 21, 2008
    2,745
    665
    nsaspook likes this.
  7. GopherT
    Nov 23, 2012
    6,297
    4,019
    The ringing might be from the scope probes - the capacitance in the scope & probes. Try turning the probe to 10x and turning up the gain on the scope by 10x. Signal should be the same size on the screen. If the ringing goes away, it was because the output impedance of your test point was too high for the 1x setting on the oscilloscope probe.
    EDIT: I just looked at your schematic, the capacitive load you are driving will cause the ringing. Put a buffer between your receiver op amp and you capacitive load. Ringing should go away.
  8. Boomin Perera
    Aug 27, 2015
    6
    WDM -Wavelength Division Multiplexing (sorry for the confusion)
  9. Boomin Perera
    Aug 27, 2015
    6
    -The stated bandwidth of the photo-diode is 90MHz . It should be fast enough
    -I'll try it , but doesn't oscilloscope have 50 ohm resistor between probe and ground terminal
    -I have it on a breadboard yes it has a ground plane connected to a voltage supply. Do you think using a PCB might help in this case?
    -I am not too sure what does decoupling mean exactly , (does mean to use bypass capacitors)
    -I'll upload my signal soon (but currently it looks like the bottom picture)
      File size:
      11.8 KB
  10. Boomin Perera
    Aug 27, 2015
    6
    I tried using my photo-diode in this configuration , i wasn't able to get any output through this ( I wasn't too sure why)
  11. Boomin Perera
    Aug 27, 2015
    6
    Thanks alot , I'll try your suggestions and get back to you. (I am using a BNC connector at the oscilloscope terminal do u know what the probe setting of that is (10x or 1x))
  12. GopherT
    Nov 23, 2012
    6,297
    4,019
    There is likely a switch on the probe...
    Like this.
  13. ronv
    Nov 12, 2008
    3,391
    1,446
    I think Dick is correct.
    Take a look at this write up and see if it will help.
    http://www.ti.com/lit/an/sboa061/sboa061.pdf
  14. DickCappels
    Aug 21, 2008
    2,745
    665
    @Boomin Perera , To use the opamp as a transimedance amplifier you need both a positive and negative power supply, or you ned to reference the non-inverting input of the opamp and the anode of the diode to a voltage above ground.
