equaliser to PC
Discussion in 'General Electronics Chat' started by simontheng, May 12, 2011.
  1. simontheng
    May 12, 2011
    Hi all, i was stucked at this stage.
    receiving audio after ADC then show it as a real time equaliser to a desktop gui.
    how should i go about it?
    thanks for the help :)
  2. DumboFixer
    Feb 10, 2009
    219
    34
    I imagine that you'll have to get the data into the PC if its from an external source (via USB?), then you'll need to process the data to split it into its various frequencies, then you'll need to write an application to display the data in a GUI.
    You'll need to provide more detail if you want a realistic chance of getting help.
    simontheng likes this.
  3. t06afre
    May 11, 2009
    5,939
    1,222
    Most PCs to day have an onboard ADC and DAC. And that is the sound card.
    Also remember that good questions draw good answers. Try rephrasing your question. So we have a better understanding of what you have done so far, and why and how you struggle
  4. simontheng
    May 12, 2011
    yep i already have ADC & DAC on board on my PCB.
    using rs232 to transfer the data to PC.
    i have 8 different frequencies assigned. So am i right to say that, inputs have to be matched(how?) and if matched, the signals are travelled via rs232 and it will reflect on the desktop gui.
    erm..... i'm clueless. Pardon me if you don't understand it :confused:
  5. t06afre
    May 11, 2009
    5,939
    1,222
    Sorry I do not understand still. Can you draw a schematic describing what you are trying to do. Or perhaps just post the assignment description.
  6. simontheng
    May 12, 2011
    Hi thanks for attempting to answer it.
    Basically i'm building a audio spectral analyser, it must be capable to pick up the tones and transmit via rs232 to the PC. The desktop GUI must show the real time equaliser. i have been looking on youtubes, they are capable to show it on the LCD itself.
    But that's not 1 want, i wanted to show it on the PC :) or is it the same approach?
  7. Laz Baz
    May 29, 2011
    6
    Since DACs are mentionedhere, I would like to ask:
    1. I am not satisfied with the playback of a music track ripped to FLAC (stored on an external HD) from a CD. The EHD is connected to my AV receiver via the USB input and the FLAC file is played. It sound inferior to the original CD track-it should not as the lossless data is exactly the same as the CD data. Where is the conversion degrading the quality?
    William
