Equal Resistance
Discussion in 'Homework Help' started by js2006, Oct 18, 2006.
  1. js2006
    Oct 18, 2006
    how can we Find REQ and Io.
    in the given circuit diagram
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Step 1: Redraw the circuit to better reveal which resistors are in parallel and which are in series.
    Step 2: Combine the series resistances.
    Step 3: Reduce any parallel resistances using the formula for resistors in parallel.
    Step 4: Repeat steps 2 and 3 until you have reduced the resistor network to a single equivalent resistance.
    Step 5: Apply Ohm's Law.
    hgmjr
  3. js2006
    Oct 18, 2006
    Thanks , the steps helped me around first i think we will shorten the circuit by finding Req and then using Ohms law to find Io.
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    js2006,
    I think you have the idea now.
    If you get stuck on any of the steps let me know and I will try to get you moving again.
    Let us know what your final answer is.
    hgmjr
