Epochs and Orbits.
Discussion in 'General Science' started by BR-549, Jan 23, 2015.
  1. BR-549
    Sep 22, 2013
    2,181
    419
    When Coulomb came up with the charge equation......it was very similar to Newton's gravity equation.
    Not long after that it was discovered that when you move the charges.......you have to add another term to the equation......a magnetic term to describe the interaction.
    It has been found that this is true for the gravity equation also. Newton's static equation needs another term too, when the bodies are moving.
    When we measure gravity on earth......we are so far out of gravitational equilibrium, that we only see the first term.
    To see this second term we must be in stable orbit....at equilibrium.
    The second term added to Coulomb's equation causes the charge to spiral or move in a helical fashion.
    This second term added to Newton's equation causes the mass to spiral in a helical fashion also, but it is ~10^40 times weaker.
    An object that is in stable orbit does not follow a elliptical path as observed and measured.
    That is what is so confusing about it. It appears to follow a elliptic, but it doesn't.
    The orbital path is a helix. As the earth orbits around the sun it follows a one turn helix.
    This helix carves out a toroid of space with the sun in the center. The center of the earth will always be somewhere on the surface of that toroid.
    When the earth is on the outside of the helix or toroid, it is in apogee. On the other side of the sun, the earth will be on the inside of the toroid....perigee. But the sun is always in the center of toroid.
    If you look up orbital parameters and orbital elements, you will see the way that epochs are found. An epoch is the position in orbit at a particular time.
    I suggest a much easier way.
    The distance from the sun, along with the angle of inclination, will give us the radius of the toroid. We will call this value Q.
    The rotation rate of the toroid is 2 pie and the period is one year. We will call this value I.
    These Q and I values plot the location on the surface of the toroid. Instant epochs.
    Not bad huh. That seems a lot easier to me. I wonder if NASA could use this.
    Force interaction is a orthogonal process. It takes 3-D movement to balance.
    When ever you see a ellipse in nature.......you are looking at a toroid.
  2. nsaspook
    Aug 27, 2009
    3,013
    2,362
  3. BR-549
    Sep 22, 2013
    2,181
    419
    Sometimes a diagram can clarify a description.
    Ignore the self spin of the earth, and use the solar equatorial plane for reference.
    Pick one of the points where the inclination is maximum. These two points are equidistant. Let's say the bottom left hand side.
    This will be the origin of the "orbital signal".
    As the earth comes out of the page....it will rotate up and around the outside of the toroid, to the top of the right hand side. This is the apogee arc.
    As the earth at the top right hand side and goes into the page....it will rotate down the inside of the toroid, to the bottom of the left hand side. This is the perigee arc.
    The difference in position of where the orbits starts and where it ends....is called orbital precession.
    When we started analyzing the data from Io, because of volcanoes and Jupiter's magnetic field ....an ionized toroid was found around Jupiter in Io's orbit. NASA predicted that Io would be in elliptical orbit inside the toroid.
    It was found that Io rotated around the toroid. NASA calls it a gravitational anomaly, because of other moons.
    When the Saturn ring data was studied....it was found all those little ice cubes were flying in helical formation.
    Earth's toroid will not stay exactly centered on the sun. This is because the sun travels in a helical manner also and has some lateral component.
    If you plot the helical arc of the sun.........you can find the object that is affecting it the most.
    If you continually follow the arcs of galactic helixes....you will find the center.
