Entanglement theory - Electronics?
Discussion in 'Physics' started by Skeebopstop, Feb 2, 2009.
  1. Skeebopstop
    Thread Starter Active Member
    Jan 9, 2009
    358
    I recently read that entanglement, something I thought still entirely theoretical, is being applied to quantum computers!
    Does anyone know anything of this? How does it work? How do they control or generate entangled electrons?
    Help me get a grip on reality again please! This is blowing my mind if it is true.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    If you have not already reviewed the material in Wikipedia on the subject of Quantum Entanglement Theory then here is a link.
    hgmjr
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    Here's something from Science News (January 22, 2009):
    John
  4. Skeebopstop
    Jan 9, 2009
    358
    I just had a read and it appears that much is still shrouded in theory, i.e. locality and speed of transmission.
    So if I am correct, entanglement is not at this time being considered for a communications stream faster than the speed of light?
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Only in science fiction so far.
  6. Skeebopstop
    Jan 9, 2009
    358
    So basically, they are just trying to use entanglement to increase the bandwidth of a qubit computing?
    Anyone know of any logic gates etc.. where such entanglement may be helpful?
  7. gregdevid
    Member
    Feb 4, 2009
    18
    Hi ,
    It is often said that instantaneous signaling through quantum entanglement is impossible because of Eberhard’s theorem that basically says that since local measurements always produce random results no information can be sent through quantum entanglement alone (Eberhard, 1978). However, there are at least two ways to circumvent this impossibility. The first is to assume that the statistical distribution can be modified and utilized to transmit information. Quite a few authors have expressed this view especially when discussing the roles of consciousness in parapsychology such as telepathy. The second is to assume that each quantum entity can directly sense and utilize quantum entanglement as already mentioned before.
  8. Skeebopstop
    Jan 9, 2009
    358
    Assuming the latter of your responses true, i.e. my initial inquiry, I see no reason why the technology couldn't evolve rapidly. MRI, although still limited in resolution, measures the spin of nearly individual atoms. Therefore sensing the spin of individual atoms should be a possibility in the future.
