Enough to make a grown man cry.
Discussion in 'General Electronics Chat' started by KL7AJ, Mar 18, 2009.
  1. KL7AJ
    Thread Starter AAC Fanatic!
    Nov 4, 2008
    2,043
    292
  2. steveb
    Jul 3, 2008
    2,433
    469
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The really sad part is that someone may actually buy them.
    And the seller may try cleaning a rifle one day....
  4. PRS
    Aug 24, 2008
    989
    35
    Whatever it was, when I got to it there was a blank page with a notice: This page has been flagged for removal.
  5. kubeek
    Sep 20, 2005
    4,686
    805
    So I ask, what was it?
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The offering was a number of vacuum tubes. The "seller" had found that the glass envelope with the getter flash obscured the inner parts, and had broken all the glass off to expose the insides.
    As the ad has been flagged for removal, it may have been a hoax. Painful to see the broken tube, though.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Here's the text from the ad:
    "Hi i have 8 7591 vacuum tubes that were new old stock, i tested these in a scott amplifier and worked well. I carefully removed the glass on each tube to clean both sides as all the tops had silver inside blocking view of tubes light now the tubes have no glass but may still work. asking 50.00 each."
    The gene pool is indeed in need of chlorine... ;)
  8. thatoneguy
    Feb 19, 2009
    6,357
    718
    It seems that Darwin's pool boy has been out of chlorine for a while now. :(
  9. Audioguru
    Dec 20, 2007
    9,411
    896
    Like the Arabs who threw away the air filters on their new American cars when the filters got clogged with sand.
