Engineer's Thumb Compressor
Discussion in 'The Projects Forum' started by Geoffb, Mar 21, 2015.
Thread Status:
Not open for further replies.
  1. Geoffb
    Nov 4, 2012
    Hi Folks,
    I've built an engineer's thumb using the JMK PCB rev 1.2 and I can't seem to get the circuit to start and compress until the input is greater than approx 600mV p-p. I'm looking for compression by monitoring the input waveform (1kHz) with one channel of a scope and the output with the second channel and I can't see the output compressing until the input is approx 600mV p-p.
    Here's a link to the circuit http://jmkpcbs.com/wp-content/uploads/2014/08/Engineers-Thumb.pdf
    The following are DC voltage readings with no signal (9v power):
    TL074
    pin 1 =4.69v
    pin 2 =4.51v
    pin 3 = 4.11
    pin 4 = 0v
    pin 5 = 4.11
    pin 6 = ?
    pin 7 = 4.56
    pin 8 = 3.86
    pin 9 = 4.4
    pin 10 = 4.02
    pin 12,13,14 = 4.5v
    CA3080
    pin 2 = 4.51v
    pin 3 = 4.51v
    pin 5 = 0.69
    pin 6 = 4.51
    I beleive the problem has something to do with the precision rectifier circuit as the waveform on pin 1 of the TL074 looks nothing like half wave rectification, in fact the waveform is still a full sinewave until the above 600mV input is reached and only then does the bottem of the negative half cycle start to show signs of a more negative spike. I've even tried simulating this circuit using 5Spice which seems to give the same results. All the precision rectifier circuits I've seem on the internet have the feedback to the same input as its signal input. The only changes I've made from the orginal circuit are using 1uF electro in place of C5 and C6 and a BC 327 in place of Q1.
    I would appreciate if someone with more knowledge of the type of circuit give me some advice, please?
    Regards
    Geoff
  2. WBahn
    Mar 31, 2012
    18,085
    4,917
Thread Status:
