energy store(flyback converter)
Discussion in 'General Electronics Chat' started by TAKYMOUNIR, Mar 19, 2013.
  1. TAKYMOUNIR
    Thread Starter Active Member
    Jun 23, 2008
    351
    in flyback converter where the energy stored in core or in air gab or in winding
    thanks
  2. bountyhunter
    Sep 7, 2009
    2,498
    507
    I believe it's actually stored in the core, although if the core is gapped there may be some stored in the flux across the air gap.
    TAKYMOUNIR likes this.
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Isn't the energy in the magnetic field, which in most cases passes through the core (solenoid), or is entirely contained within the core (toroid).
  4. Sue_AF6LJ
    Member
    Mar 16, 2013
    45
    27
    In a word or seven; Yes the energy is stored in the magnetic field, the core has the effect of concentrating the lines of magnetic flux.
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    The OP's question regarding the flyback converter was clearly about energy storage in the transformer. So I guess their question has been answered.
    One might extend the notion to any physical situation in which an electric current exists - there will be energy "stored" in the magnetic field created by the current.
    If you have ever had a shock off an auto ignition coil you get a very clear sense of that energy.
    One however should not forget that there is a second energy storage component in the flyback converter - namely the capacitor.
  6. crutschow
    Mar 14, 2008
    13,515
    3,386
    Which stores the energy in the electric field, of course. ;)
