Energy storage within two-port networks.
Discussion in 'General Electronics Chat' started by WBahn, Feb 17, 2014.
  1. WBahn
    Thread Starter Moderator
    Mar 31, 2012
    18,064
    4,904
    Here's the deal. The textbook I am using (Nilsson and Riedel, Electric Circuits, 9th Ed) has a chapter regarding two-port networks and there are a couple of things that don't make a lot of sense to me. In particular, they state that the first restriction on a block that is to be modeled as a two-port network is that it can have no energy stored within it (note that this is in addition to the restriction that it can't have any independent sources, so that isn't what they are referring to).
    They don't clarify it any more than that (that I can see). In particular, they don't explain the reason for ANY of the restrictions, which is frustrating. But this restriction would seem to indicate that there can't be any reactive elements with a two-port network, yet that would not only seem to defeat much of the utility, but it is also counter to many of the networks that they have in the problems for the chapter. So just what are they talking about?
    I have to admit that I have done very little directly with two-port networks (though certainly many of the things I have done over the years would probably fall into this category if looked at the right way). In looking over information online, I can't find any place else that places this same restriction on the circuits in such a network, at least not in so many words. So I'd like to get some of your thoughts on the matter.
    Thanks.
  2. Tesla23
    May 10, 2009
    323
    67
    It seems like a strange statement.
    When studying passive two ports it is usual to require that there are no internal sources of power, this allows you to assert that the power leaving the two port won't exceed the incident power, which leads to useful properties of the various circuit matrices. I suspect this is what they mean. No reactive power would mean studying resistive circuits only - is that what they are doing?
    The best thing to do is to scan the chapter and see where they use this assumption, if it is well written this should be clear.
  3. WBahn
    Mar 31, 2012
    18,064
    4,904
    Funny you should suggest that. I have access to the electronic version and I searched the entire chapter for the word "energy" and got exactly two hits:
    In the chapter overview, where it says, "First, there can be no energy stored within the circuit."
    In the chapter summary, where it says, "The model is limited to circuits in which no energy is stored inside the circuit between the ports."
    So I can't use context of use to figure out what they heck they mean!
    I don't know that I can claim that this book is "well written". There are lots of worse texts out there and this one has some redeeming features, but on balance I think I dislike it more than I like it.
  4. nsaspook
    Aug 27, 2009
    3,006
    2,348
    Do you think they are implying no 'initial' energy storage and the network reactive elements are at a zero energy state before any external sources are connected.
  5. WBahn
    Mar 31, 2012
    18,064
    4,904
    I don't think so. It sure doesn't read like it. Plus, in the earlier chapter where they introduce the concept of a "transfer function" they are pretty explicit about stating that very condition.
    I'm coming to the conclusion that they are simply wrong. There are a couple other places in the text where that is the case, so it doesn't come as a complete surprise.
  6. GopherT
    Nov 23, 2012
    6,297
    4,019
    If it is so unclear, send her an email and ask.
    http://www.marquette.edu/engineering/electrical_computer/facstaff_riedel.shtml
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    Perhaps that no independent energy sources may 'reside' in any 2-port.
  8. studiot
    Nov 9, 2007
    5,005
    515
    This one should please Tesla since Gatland is from downunder.
    Electronic Applications of Two-Port Networks
    Gatland
    Advanced Electrical Engineering
    Morton
    Active Network Theory
    Haykim
    Higher Electrical Engineering
    Shepherd, Morton and Spense
    Extract from the last mentioned
    So I guess that Nilsson is referring only to passive two port networks.
    I do not have your book, in the one by Nilsson I have (Electric Circuits) his very short chapter does seem only to discuss passive networks and places the sources at the terminals. However he introduces some active two port networks in the questions at the end.
    Go figure.
  9. WBahn
    Mar 31, 2012
    18,064
    4,904
    Thanks for the link. I couldn't find any contact information on the publisher's website and didn't try any harder.
    I've sent her an e-mail about this and also about some other questions regarding their material on the initial- and final-value theorems of the Laplace transform. I'll let you know what (assuming if) I hear back.
  10. WBahn
    Mar 31, 2012
    18,064
    4,904
    So, I heard back from the author. nsaspook nailed it -- they meant that the initial energy needed to be zero. This makes sense if you have the restriction that there can't be any independent sources since any initial energy stored in a reactive component will effectively be transformed into an independent source when you take it into the s domain.
    She also agreed that their wording on the constraints on f(t) and F(s) relative to the initial- and final-value theorems for the Laplace transform was confusing/misleading and will be revising that.
    tshuck likes this.
