energy conversion
Discussion in 'Physics' started by praondevou, Dec 17, 2012.
  1. praondevou
    Thread Starter AAC Fanatic!
    Jul 9, 2011
    2,936
    489
    Are there any other efficient conversion principles to convert electricity into kinetic energy other than the one based on magnetism (motors)?
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I suppose you could make an electric bottle rocket. Heat up the fluid with a battery and a nichrome wire, release the latch and have the hot gas/fluid expelled from the container.
    Oh....you meant a useful conversion of electricity to kinetic energy.
    praondevou likes this.
  3. davebee
    Oct 22, 2008
    539
    46
    Motors have been made that convert electrical energy into kinetic energy using the electric force rather than magnetic force; so-called static electric motors.
    They are not inefficient, as far as I know, but the technology for managing extremely high voltages has never been advanced enough to make these motors practical. I have read that they may be useful in nanomachines, though.
  4. Lucian Solaris
    Jan 14, 2013
    5
    You could use the electric current to perform an electrolytic action, whereby you break down the product(s) of an oxidation process, capture them, then rapidly oxidize the products of this electrolytic process in a directional chamber. This is thought not to be very efficient, but it will work.
    (like 2H2 and O2 make 2H2O when oxidized, while an electrolytic cell will take 2H2O and break it down into a gas of 2H2 and O2)
  5. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    A resistor is 100% efficient, but the thermal kinetic energy is probably not what you are thinking of.
  6. THE_RB
    Feb 11, 2008
    5,435
    1,305
    But the heat produced can be used to cause mechanical motion? Ie steam engine, thermal expnasion, bimetallic strip etc.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    The electrolysis process itself is pretty inefficient.
    Ever check out Stirling Engines?
  8. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    placeholder for removed spammers post.
    will be removed when new post is made.
