Endian???
Discussion in 'Homework Help' started by mnunez021, Mar 29, 2009.
  1. mnunez021
    Feb 27, 2009
    18
    Big Endian
    Location Contents (Byte)
    20:
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    What answers have you got?
    There are many sources of information on the internet that can help you answer this question. Google is a terrific tool for the purpose.
    hgmjr
  3. mnunez021
    Feb 27, 2009
    18
    Big Endian
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    Did you run across this presentation on "endianness" in Wikipedia?
    hgmjr
  5. mnunez021
    Feb 27, 2009
    18
    yes and still made no sense... i even saw an example 1234567 stored in 0 ans still made no sense
  6. Ratch
    Mar 20, 2007
    1,068
    mnunez021,
    Big endian used in Motorola micros
    20: 00
    21: 00
    22: 08 hex
    23: 01 hex
    Little endian used by Intel micros.
    20: 01 hex
    21: 08 hex
    22: 00
    23: 00
    Endian describes the way a word is stored in memory. As a programmer, you usually don't have to worry too much about it unless you address a partial word with a byte instruction. Intel reverses the bytes, but not the bits within the bytes.
    Ratch
  7. hgmjr
    Jan 28, 2005
    9,030
    214
    This figure from Wikipedia appears to spell out the technique fairly clearly.
    Are you still confused?
    hgmjr
  8. hgmjr
    Jan 28, 2005
    9,030
    214
    Do you see what you overlooked in your first attempt?
    hgmjr
  9. mnunez021
    Feb 27, 2009
    18
    Big Endian
  10. mnunez021
    Feb 27, 2009
    18
    Big Endian
    L
  11. hgmjr
    Jan 28, 2005
    9,030
    214
    Sorry. The answer is incorrect. Keep in mind that the value as stated in the problem is expressed as a decimal value. You will need to do a bit of converting first before you tackle dealing with the endianness.
    hgmjr
  12. mnunez021
    Feb 27, 2009
    18
    would i have to covert it to binary?
  13. hgmjr
    Jan 28, 2005
    9,030
    214
    Yes. You may recall from your studies that memory contains values expressed in binary. Hexadecimal notation is commonly used when expressing 8-bit values so I would suggest you consider taking that conversion as your first step. Did your instructor mention that you would be dealing with hexadecimal values when this problem was assigned?
    hgmjr
  14. mnunez021
    Feb 27, 2009
    18
    no and the section covers very little
  15. hgmjr
    Jan 28, 2005
    9,030
    214
    Are you familiar with hexadecimal notation at all?
    hgmjr
  16. mnunez021
    Feb 27, 2009
    18
    yes i am. i even have a cal just in cause
  17. hgmjr
    Jan 28, 2005
    9,030
    214
    Then go ahead and convert it and then use that number in place of the number you used in reply #3. I think that will get you where you need to be.
    hgmjr
