Encoder
Discussion in 'Homework Help' started by av.k10373, Nov 21, 2007.
  1. av.k10373
    Nov 21, 2007
    Dear Sir,
    Attached here some details of a 9 bits parellel output encoder.
    Can we make a test circut with digital counter display unit in decimal
    and binery mode ?
    Spec: 9 bits output, 0 to 360* counting, 3000 rpm,
    Ajith karthikeyan
    ajithkarthikeyan@yahoo.co.in
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Well, the output is already in binary, so that part is already done. Converting to degrees might be a challenge, as there are more than 360 counts/revolution. Unless, of course, you know more about the encoder that we do.
    You could go through a lot of discreet logic to convert to decimal. Must the count in decimal be in degrees, or just be the equivalent number?
    The first solution is going to need a microprocessor. The second can use several gates to monitor bit 1 & 2, and count up a decimal counter string.
  3. GS3
    Sep 21, 2007
    408
    35
    One possible approach might be to convert digital to analog and then just measure the analog signal with a meter which will have its own built in ADC. That seems pretty simple.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It's going around Robin Hood's barn, but the D to A converter's output could be scaled to more closely work with the A to D to give an output that reads in degrees.
  5. Ron H
    Apr 14, 2005
    7,050
    657
    How do we know the output is in binary?
  6. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The OP has that information.
  8. Ron H
    Apr 14, 2005
    7,050
    657
    What information? (This is beginning to feel like "Who's on first?" by Abbott and Costello.):D
  9. GS3
    Sep 21, 2007
    408
    35
    If the output is in Gray code rather than straight binary then my suggestion does not work (obviously). I had not thought of that.
  10. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Nobody but the OP has any information about the encoder, other than it's got a nine bit output.
