Emp motor coil
Discussion in 'General Electronics Chat' started by Andy Larson, Mar 28, 2015.
  1. Andy Larson
    Mar 26, 2015
    51
    I got a motor coil on the shaft still with contact plates and gear intact, and I was wondering if it could be used to generate an EMP or be used as an induction coil.
  2. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,510
    Need ( a lot ) more details?
    Max.
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    An EMP requires the detonation of a nuclear weapon, or a lightning strike. As such it would be contrary to the TOS and general sanity.
  4. Andy Larson
    Mar 26, 2015
    51
    I have done my research my friend. EMPs can be generated with a quick and sudden high voltage to a induction coil or and coil really
  5. Andy Larson
    Mar 26, 2015
    51
    the question should be. Do motor coils count as induction coils? The part the recieves the electricity and does the majority of the work
  6. bushrat
    Member
    Nov 29, 2014
    97
    23
    should be quite educational for your topic..
  7. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,510
    Induction usually means a voltage is induced in a coil by magnetic effect.
    The 'shorted' turns on a induction motor rotor is an example, and that is only one turn.
    Max.
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Voltage really doesn't matter to an inductor, current is the thing.
  9. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    The American military has been developing an EMP gun which combines a heavy coil with a shaped charge explosive.
    I only glossed over the article, but I gather its basically a funnel shaped spiral conductor encased in explosive - when its detonated, the inductor collapses to much smaller dimensions, that produces an abrupt risetime in the current through it which comes pretty close to EMP.
