Forum Suggestion Emoticons.
ScottWang
Joined Aug 23, 2012
7,399
Welcome to the AAC ... :)
I'm not sure what kind of the reason that you felt that bad in your "first post", unless other members to do something bad to you, otherwise those emoticons(emotions symbols) will be keeping that way, this forum is a educational website, the members will and know to keep the forum have a good mood, some may like to make joke, arguing for the theories, if no harm and nobody get hurt then everything will be going to normally, sometimes we can't hope everything will be as our wish, but you can ignore it, good luck and have fun in this forum.
atferrari
Joined Jan 6, 2004
4,768
Not only the emoticons but the stupid PNP transistors always hanging from the +V rail, never putting their feet on the ground!
First troll I find funny and inspiring....l:p
ScottWang
Joined Aug 23, 2012
7,399
No, no, no.
In the old time, the PNP were occupied the ground, they were everywhere, you can't or not easy to see a npn on the ground, during that time, even the plug, the positive voltage also occupied the ground, on these day, if you got an old machine and you are not careful then you could be damaged the machine, I bought a second hand ESCORT EDM-2347 multimeter from school that the power plug just like that, so I did a adaptor to reverse the polarity then I can using the modern normal adaptor(power supply) to plug in.
