Emosfets
Discussion in 'General Electronics Chat' started by rougie, Nov 22, 2012.
  1. rougie
    Thread Starter Active Member
    Dec 11, 2006
    410
    I would like to experiment with N-Channel enhancement MOSFETS.
    Which part # EMOSFET should I purchase that comes close to the MOSFET described at 12:30 of the following video:
    http://www.youtube.com/watch?v=NSD7n7CR5cM&feature=channel&list=UL
    There are so many out there that I don't know which one to start with!
    Here are some details:
    Channel type: N channel (built by minority carriers)
    Max source voltage: 6 to 10 VDC
    Max drain current: 50 ma
    Threshold voltage: Approx: 1V
    Package type: TO92
    Any suggestions would be very appreciated!
    r
  2. tshuck
    Oct 18, 2012
    3,531
    675
    I personally like the 2N7000, as these have a higher current capability, but either should work...
  3. rougie
    Dec 11, 2006
    410
    Hi tshuck,
    I would like to ask you a question.
    There is a mosfet called "Depletion/Enhancement Mosfet" which can be used in two modes either depletion or enhancement.
    However there is another type of mosfet called "Enhancement mosfet" which is the one I am looking for and shown at 12:30 of the following video:
    http://www.youtube.com/watch?v=NSD7n...hannel&list=UL
    This type of mosfet simply accepts positive threshold voltage at the gate which allows an N-channel to be formed by minority carriers connecting the drain to the source. The higher the gate voltage above the Voltage threshold, the more minority carriers form creating a bigger N channel thus allowing more current through drain/source. Is this exactly what the 2N7000 part does?
    thank you so must for your help !
    r
  4. rougie
    Dec 11, 2006
    410
    hi tshuck,
    Your 2N7000 works.... I really thank you for your recommendation and help!
    regards
    r
