Emitter follower gain
Discussion in 'General Electronics Chat' started by Gordon Freeman, Oct 1, 2016.
  1. Gordon Freeman
    Sep 6, 2016
    18
    I am calculating the gain of a common collector amplifier. It seems that Vout =Vin and the gain is always 1. Anything wrong?
  2. DickCappels
    Aug 21, 2008
    2,782
    675
    Very close, at least for small low frequency AC signals.
    The emitter has some resistance (dependent upon current and temperature), so if the emitter load is anything other than an ideal (infinite impedance) current source you will have some loss because of the drop across the emitter resistance.
    Gordon Freeman likes this.
  3. Gordon Freeman
    Sep 6, 2016
    18
    Thank you!
  4. hp1729
    Nov 23, 2015
    2,105
    235
    Voltage gain, current gain or power gain? Yes, voltage gain is not the objective in that circuit.
  5. crutschow
    Mar 14, 2008
    13,520
    3,386
    That's why it's called an emitter follower circuit.
    The emitter basically follows the base.
