I'm trying to design the input stage for an EMG amplifier. I'm using an INA118 with a split supply (5 V for V+ and 2.5 V for V-). I've used two DC sources but in the actual circuit I will probably use a rail splitter.
I've tried to simulate the circuit in TINA-TI but the output is wrong. The input is a 5mVpp sine wave with the INA amp gain of 10 and a DC level of 1 V (This is so it exceeds the common mode requirement of 0.98 V). The output appears to be garbage.
So there's obviously something I don't understand, or am missing. There are many parameters to take into account and the sheer number of graphs are overwhelming. If someone can point me in the right direction, it would be good.
