I would like to do something like
I would like to try this circuit but the closest thing I was able to get was a http://www.farnell.com/datasheets/1924947.pdf?_ga=1.127058958.2085444920.1456966239, I set up the antenna on G which is the third legI believe, I set up the vcc on the middle leg and the led on the first leg all in reference to the front facing me. I will try combing my hair 5 feet from the antenna to see if it works, but is this the correct setup?
by Jake Hertz
by Jake Hertz
by Aaron Carman
by Jake Hertz
