OK,
Look at my schematic.
As you may see there;
1. The line. The line is use to separate the flooring.
2. The bulbs on the ground floor have light gray background. The light gray background is the water or the flash flood.
The battery was in the second floor.
Okay,
As you may notice, I put switch and fuses. Both negative and positive.
Why? So that, if there is any events like that, I can just off the switch so other lines will not be affected.
Please veteran guys, tell me if it is okay.
Okay,
