OK, if you're going to be using those "superbright" high-current multileg LED critters, they generally draw around 70mA @ 3.4-3.9V, depending upon the color you choose (different colors have different chemistry in the PN junction, thus emit different frequency light, and require different voltage levels; blue and white LEDs tend to be higher voltage than the rest.)
So, let's say you were using white LEDs rated for 70mA @ 3.9V
14V / 3.9 = 3.58+
So, three in series
Limiting resistor:
E = 14V - (3 x 3.9)
E = 14 - 11.7
E = 2.3
OK, now let's get 70mA across 2.3V:
R = E / I
R = 2.3 / 70mA
R = 2.3 / .07
R = 32.85 Ohms
Closest resistor is (conveniently!) 33 Ohms
But now we're starting to get some serious current through our resistor - better check to see what the wattage requirement is:
P = E x I
P = 2.3 x .07
P = 0.161 Watts
You'll need to use 1/4 Watt or higher rated resistors.
Ok, so 3 per string @ 70mA.
5.6A / 0.07 = 80 strings of 3, or 240 LEDs. While a properly heat-sinked IRF510 would work, it might tend towards a bit marginal. After all, why use a 2x4 when a 10x12 will work just fine? An IRF3703 is the same physical size as the IRF510, yet will handle up to around 1000 of these 3-LED strings (proper heat-sinking applies)
14V / 3.9 = 3.58+
So, three in series
Limiting resistor:
E = 14V - (3 x 3.9)
E = 14 - 11.7
E = 2.3
R = E / I
R = 2.3 / 70mA
R = 2.3 / .07
R = 32.85 Ohms
P = E x I
P = 2.3 x .07
P = 0.161 Watts
