EMC pi filter design for cs102
Discussion in 'General Electronics Chat' started by shankar M, Jul 9, 2015.
  1. shankar M
    Mar 27, 2014
    16
    Hi
    I want to design EMC?EMI pi filter for qualifying CS102 freq range 30Hz to 150KHz
    Can any body help to design ?
    I requesting explain with formulas
  2. RichardO
    May 4, 2013
    1,341
    429
    It would help if you told us what a CS102 is and how you are using it.
  3. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,701
    1,300
    He is talking about one of the conducted susceptibility tests in MIL-STD-461, the big fat hairy mil spec for all things EMI/EMC. Pulses, noise, and other gorp can be conducted into a piece of equipment by the power input cable, get through the power supply, show up on the output(s), and wreak havoc with circuit operations. There is no standard for the amount of attenuation needed. The standard describes the noise level injected into the power line, and the requirement is that the equipment operate through the test. So the amount of attenuation depends on the sensitivities of the internal equipment, circuits, etc.
    To get a feel for the parts, start with datasheets from power line filter manufacturers. Most of them have schematics and the component values listed. Corcom, Schurter, Filter Concepts...
    ak
  4. RichardO
    May 4, 2013
    1,341
    429
    Oh, thanks.
    I was visualizing a D/A convertor or the like...
