Embedded processor for text to speech (TTS)
Discussion in 'Embedded Systems and Microcontrollers' started by navarromoral, Jul 12, 2015.
  1. navarromoral
    Jul 12, 2015
    Hello!!
    I am trying to design an embedded system with text to speech for blind people. The system can't use Linux or any "heavy" operating system because it should boot as quick as possible. My question is if someone knows a package for TTS in embedded devices. I have found flite, but I want to know if there is a better alternative.
    Thank you in advanced!
    Santi
  2. pwdixon
    Member
    Oct 11, 2012
    488
    56
    There is a project on github for an arduino based text to speech library.
    There are also text to speech arduino shields available that use text to speech chips.
    Everything sounds very robotic though. Search on google.
    Alternatively you could record and playback phrases using wav files pretty easily if you have set phrases.
  3. ep.hobbyiest
    Member
    Aug 26, 2014
    95
    Hey
    i m also interested. Can you share exact path of that github.
    it could be better than searching other library .
  4. pwdixon
    Member
    Oct 11, 2012
    488
    56
    How hard is it to use Google?
    "github text to speech library" first on the list!
    mitko89 likes this.
