embedded c alternative
Discussion in 'General Electronics Chat' started by ugeshkumar, Mar 29, 2016.
  1. ugeshkumar
    Nov 27, 2015
    16
    hi friends
    i need some guidance, i new to learn embedded, any other alternative method for doing embedded programming, because i cannot able to learn embedded c, or otherwise alternative software available to generate embedded c programs ,easily to convert logic flow chart to programs like l(ab-view )etc
    please share.
  2. mcasale
    Member
    Jul 18, 2011
    210
    12
    Are you asking if there's an alternative to C for an embedded system? Please be more specific.
  3. ugeshkumar
    Nov 27, 2015
    16
    without writing programming any other methods, @mcasale
  4. mcasale
    Member
    Jul 18, 2011
    210
    12
    So, you want something at a high level (not assembly code), but not have to generate lines of [any type of] code.
    Have you considered a PLC (Programmable Logic Controller)? There is some programming involved, but it is based in "logic decisions", not a programming language, per se. Here is an introduction to PLCs:
    https://en.wikibooks.org/wiki/Introductory_PLC_Programming
    Note: the PLC solution will most likely be more expensive.
    Can you share what your project is? You really shouldn't be afraid of C code.
  5. dannyf
    Sep 13, 2015
    2,196
    417
    Lots of such tools. Ladder logic is one. And the latest psoc from cypress is programmed fully graphically......
  6. ErnieM
    Apr 24, 2011
    7,442
    1,628
    Google something called "Flowcode." I have never used it but have seen some who have. It seems to be something exactly like what you are looking for.
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    For what purpose do you want this alternative method of doing embedded programming? Maybe you could use Swift.
  8. ugeshkumar
    Nov 27, 2015
    16
    Why I want to go alternative methods because I don't know embedded c program so I looking some another methodes
  9. Brownout
    Jan 10, 2012
    2,375
    998
    Some systems use alternative programming languages and methods. I'm not an Arduino user, so I'm speaking out of school, but it uses an, as I understand, simpler and easier to learn programming language.
