Elimantation
Discussion in 'Math' started by Steve1992, Sep 8, 2012.
  1. Steve1992
    Thread Starter Senior Member
    Apr 7, 2006
    100
    Vc - Vo = I1Rf
    Vcc - Vc = (I1 + I2)R1 (2)
    Vc-(-Vcc) = Vc + Vcc = I2R2
    Elimate I1 and I2 from the above equation and show that:
    Vcc - Vc = (Vc - Vo)R1/Rf + (Vc + Vcc)R1/R2
    I understand that I1 and I2 are replaced from (2) with (Vc - Vo) and (Vc + Vcc) but how does /Rf and /R2 slot in?
  2. panic mode
    Oct 10, 2011
    1,328
    305
    you have I1 in
    Vc - Vo = I1Rf
    which can be expressed as
    I1=(Vc - Vo)/Rf
    same should apply for getting I2 from some other equation like
    Vc + Vcc = I2R2
    I2=(Vc + Vcc)/R2
    then you replace I1 and I2 in (2) to get result
    Steve1992 likes this.
  3. WBahn
    Mar 31, 2012
    18,085
    4,917
    I don't think you do understand it, because it isn't true. I1 and I2 are currents while (Vc-Vo) and (Vc+Vcc) are voltages; you can't just replace one with the other. Hopefully panic mode's suggestion has cleared things up for you.
