elevator
Discussion in 'The Projects Forum' started by theanih, Oct 3, 2010.
  1. theanih
    Oct 3, 2010
    21
    is it possible to control a 3 level elevator (with inner and outer request buttons) without a microcontroller? is there other alternatives?
  2. t06afre
    May 11, 2009
    5,939
    1,222
    The best option will be a microcontroller, as I see it. But you can actually use many types of logic. Like discrete gates, AND, OR, XOR etc.
  3. kubeek
    Sep 20, 2005
    4,686
    805
    Just think about it. They had elevators in 1920, right? Did they have microcontrollers? No they didn´t, they could do almost anything with enough relays.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I made one for a friend to move laundry between three floors using only CMOS logic ICs. Make a flow chart and it gets pretty simple. You need switches at each floor so the logic knows where the platform is.
  5. theanih
    Oct 3, 2010
    21
    so how do you make a relay circuit for the elevator? any ideas? what kind of relays do i need for the best results?
  6. williamj
    Sep 3, 2009
    180
    32
    theanih
    Read the thread on "dumbwaiter control system". Be aware that this is for a dumbwaiter lift system and is not meant for passenger loads. Elevators contain multiple redundent safety systems and "lift" systems do not.
    williamj
    theanih likes this.
