elevator relay
Discussion in 'Electronics Resources' started by burnett, Apr 21, 2013.
  1. burnett
    Apr 21, 2013
    I have a Otis home elevator (3 stops) that needs a relay which is marked 23621 Japan RH2VUL DC24V but no brand indicated. Does any body know of a replacement?
  2. JohnInTX
    Jun 26, 2012
    2,392
    1,051
    None of the numbers come up. Can you post a picture?
    Here's a bunch of 24DC coil relays to look through to see what you might have.
  3. jp5300
    May 9, 2013
    That is an IDEC Part number. Go here and click "Documents & Downloads for coil & contact specs on that relay.
    https://www.idec.com/usen/products/Catalogs/Relays/RH/overview.html
    There are 100's of manufacturers that offer the same relay with the same blade configuration - including WW Grainger. Just make sure the coil and contact ratings are similar.
