Elevator Project
Discussion in 'The Projects Forum' started by mateenyasin1, Mar 22, 2012.
  1. mateenyasin1
    Mar 20, 2012
    6
    Well! I have to make an elevator model as a project for digital logic design!
    I've done a lot of research and saw that most of the elevator based projects were made using PLC and micro controllers, which i haven't studied yet.
    Is it possible to implement the model using relays, multiplexers, adders, subtracters, encoders and other gates!
    It seems it would become quite hard as there are a number of complications in the design!
    I have to implement
    The Priority Call
    Safety Test
    Design a door opening and closing mechanism
    As well as the inputs inside and those outside of the elevator
    a little help would be appreciated!
    :D
  2. rfredel
    Jan 23, 2011
    25
    I think, I have a circuit at home, but I'm not at home in moment. I'll be back at saturday. Then I'll send you my design.
    Regards
    Rainer
  3. mateenyasin1
    Mar 20, 2012
    6
    thanks! :)
  4. BSomer
    Member
    Dec 28, 2011
    433
    106
    Have you used or learned anything about PLD's such as a GAL or PAL? One or more of these would cut down on the amount of IC's used in the project. The project itself is completely doable with logic IC's and the sort.
  5. williamj
    Sep 3, 2009
    180
    32
    mayteenyasin1,
    There are a number of threads on this topic in the archive here, just do a search for "elevators" and I think you may find what you are looking for.
    williamj
  6. rfredel
    Jan 23, 2011
    25
    excuse me, that I contact you only now.
    I have had problems with my Internet connection.
    Here you see a link of the German original text and the translation from the book "SIEMENS semiconductors - circuits - examples from 1972 / 1973" for a lift control. I have translate it with the translation programm PROMT from http://www.online-translator.com/Default.aspx/Text
    I have redraw the circuit - diagramme with TTL - IC's, because the IC'sc used by SIEMENS are obsolete for a long time.
    I hoe, it will help you.
    http://www.rainers-elektronikpage.de/Andere_Foren/Aufzug.pdf
    Best regards
    Rainer
    PS: Sorry, if my English is not so good.
