Elevator Project (HNC)
Discussion in 'Homework Help' started by joshnmike, Nov 24, 2010.
  1. joshnmike
    Nov 24, 2010
    Hey Guys,
    Could anyone help us with a project. we have to build a four story lift using relays and proximety sensors. could anyone help us with this?:confused:
  2. JDT
    Feb 12, 2009
    658
    85
    Not really build it - you mean explain how it could be done? Or are you going to build a miniature version?
    Nowdays the control would be done with a PLC. It could be done with "relay logic" - that's how they used to do it - I expect.
    The complete system is going to be quite complicated. Start by listing your inputs:-
    • Call buttons on each floor
    • Proximity sensors on each floor - to detect that the lift is there
    • A button panel in the lift car - minimum 4 buttons - one for each floor
    And outputs:-
    • Motor forward
    • Motor reverse
    • Acknowledgement lamps in all buttons
    Start with a simple relay "hold" circuit: Energise a relay using a button. A contact on the relay takes over from the button and holds the relay energised. The relay is de-energised by another relay opening a contact...
    As I say going to be complicated!
