Elevator controller design project
Discussion in 'The Projects Forum' started by nyasha, Oct 27, 2009.
  1. nyasha
    Thread Starter Active Member
    Mar 23, 2009
    90
    I am designing a controller for an elevator. The elevator can be at one of two floors: Ground or First. There is one button that controls the elevator, and it has two values: Up or Down. Also, there are two lights in the elevator that indicate the current floor: Red for Ground, and Green for First. I am stuck on how do l add the SR latches which open and close the door when it reaches the desired elevator floor ? How can l include that in my FSM diagram ?
      File size:
      15.7 KB
      293
  2. williamj
    Sep 3, 2009
    180
    32
    nyasha
    your open/close door cicuit for the door would be enabled by the limit/proximity switch that stops the elevator at it's destination, with perhaps a slight delay to make sure that the elevator has inded stopped.
    williamj
  3. CDRIVE
    Jul 1, 2008
    2,223
    99
    May I ask what kind of building this elevator is in?
