electrons flow question (nub question)
Discussion in 'General Electronics Chat' started by mezog, Jan 16, 2008.
  1. mezog
    Jan 16, 2008
    I was wanting to know if current is going through a wire what is happening to the electron? Are they jumping from valences shell to valences shell or what.
    I forgot one thing, I only have a very basic understanding of chem (Intro to Chem).
  2. Sparky
    Aug 1, 2005
    75
    Mezog -
    This link may help a little:
    http://en.wikipedia.org/wiki/Drift_velocity
    Notice the first first section just above the derivation section.
    When an electric field is applied across a conductor the electrons move at essentially the same time - a kind of organized step sequence - by one electron moving (left for example) it provides a spot for the electron to the right to move in to.
    -Sparky
  3. mezog
    Jan 16, 2008
    So, what the link and you are saying is that the electrons are normally just in the electron cloud, but when Voltage is applied the electrons are bouncing from one atom to the next atom in the conductor. I had a hard time understanding the math, but i think that it is saying.
    I have one more question, is current or amperage the speed at witch the electrons flow.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Current is defined by movement of charge. One ampere of current is defined as the movement of one coulomb of charge ( about 6.23 X 10^18 electrons) past a fixed point in one second.
    The speed at which individual electrons travel in the conductor isn't really defined by the current. But, looking at the conductor, it is easy to say that electrons have to move faster in a small conductor than in a large one, just to move the same amount of charge in a given unit of time.
  5. sabrex15
    Jan 17, 2008
    When there is current the electrons are essentially "bumping" into each other passing that current along... kind of like newtons cradle...
  6. mezog
    Jan 16, 2008
    Hey, I have been away for a few day. I just wanted to say thanks for the help! :)
