Electronics Revision
tom6123
Joined May 31, 2014
24
Hello everyone,
Im trying to catch up on some revision but i have no clue how to do it, so ill just give the question.
A Circuit containing a transformer, Bridge rectifier, Reservoir capacitor and an additional resister/Capacitor (RC) filter circuit, is the be used to construct a dc power supply. the input voltage is 240V@ 50Hz.
The output voltage is to be 12V Dc and designed to drive a 1k Ohm load resistor.
Can anyone help me with this?
tom6123
Joined May 31, 2014
24
I have to make a circuit from this. im currently trying to draw one. i will post it in a second for suggestions. or corrections
30,824
There is a significant piece of information missing in the specifications:
What is the amount of output ripple allowed?
tom6123
Joined May 31, 2014
24
well to be honest. the information given is all that is given. the diagram that is meant to be produced isn't going to be placed into practical form and is just meant to be bare basics.
Sparky49
Joined Jul 16, 2011
833
I think you have mistaken the load resistance for the R in the filter. If it's the load, it should be across the output.
What puzzles me from the context is that it gives a set DC output (12V), but no other parameters. Is this for a coursework or just a practice question? I would consider asking your tutor if components are required to have values, or just the layout is all that is required.
I had a similar (slightly more complex) question in my end of year exam, where we were tasked to create a +-12V supply. Was a bit easier as we weren't limited to components, so I could just wack in a couple of regulators and that was that, lol.
What do you think? If the layout is all that's important, I would simply leave component values out, otherwise, I would recommend you choose and output voltage from your transformer.
Regards,
Sparky.
tom6123
Joined May 31, 2014
24
Thanks for your reply.
This is one of the past electrical and electronic principles questions. i have been revising past papers to get a feel of the exam.
But I've been told there is a similar question to this, yet I've not been able to learn this subject because i was sick when this was meant to be taught, so i had a stab in the dark and tried to work it out myself.
but the question has some subs, for instance
"Draw the appropriate circuit using relevant component values"
Sparky49
Joined Jul 16, 2011
833
Okay, I would suggest starting with an output value for your transformer. The exactly value isn't too important in this case, just so long as it is a bit higher than your output.
Then using a bit of simple parallel/series resistor equations you should be able to calculate the ratio of resistances needed, and from there you can choose their values.
MaxHeadRoom
Joined Jul 18, 2013
28,699
One vital piece is your secondary should be no higher than 8.5vac.
R1 is high for a Pi filter, normally an inductor would be used in place of R1.
Is R1 what you call your 'Load' resistor?
Max.
JoeJester
Joined Apr 26, 2005
4,390
In your diagram, label the parts according with the names in your problem statement.
tom6123
Joined May 31, 2014
24
Im hoping this is what you meant, maybe you can shine some light on my problem
sorry forgot output voltage
JoeJester
Joined Apr 26, 2005
4,390
Correct, except that R1/C2 is the RC filter ... not additional resistor/capacitor.
Also, the load connection on the ground side is not connected to the ground ... see the circled area.
Now, check your instructions carefully or check with your instructor, to find out the ripple .... or a figure could be determined here.
what do you think the ripple frequency is?
tom6123
Joined May 31, 2014
24
it is kind of the values of the circuit that are over my head, i was regrettably sick of pneumonia when i was meant to be taught this.
would it be possible for you to give me a step in the direction?
JoeJester
Joined Apr 26, 2005
4,390
Did you read that section of your text book? What text book are you using?
http://www.zen22142.zen.co.uk/Design/dcpsu.htm is an easy read that can help you.
To make it easier and ensure we are on the same page,
Select your transformer from your favorite webstore ... like mouser, Newark, farnell, whatever, and create the bill of materials list. Select the resistor value from the E24 series (5%) in the pdf below and select the capacitor value from the aluminum electrolytic from the pdf below. Design for the ripple below 5 percent without the RC filter circuit.
