Electronics Proyect
Discussion in 'Homework Help' started by iqjavier, Feb 22, 2005.
  1. iqjavier
    Feb 22, 2005
    Greetings!
    Our professor gave us an assignment but failed to explain how to do it correctly. I have search online for a while and cannot seem to get good information. I need to bias a BJT used in the CE configuration. Only specs are that peak power output = 0.5W, Rload = 8 ohm and Fh = 20kHz and Fl = 20 Hz. That's it basically there are 4 capacitors. Cc, Ce, Cb, and a C between base and collector. Please help me go on the right direction atleast.
    Sincerely,
    Javier Malavé
  2. dragan733
    Dec 12, 2004
    152
    In the attachment is the solution
    Regards
