electronics project instruction needed...
stonewhite
Joined Mar 8, 2013
hello--
The project is a device that generates what is termed 'white noise,' i.e., a steady hiss or static sound to cover noise spikes. This noise-spike screen is useful for, e.g., those with insomnia living in a boisterous environment.
At any rate, I would need instructions--or, a link to same--which detail the items needed and the assembly of the device. A two to three inch speaker, a potentiometer, a transformer (I would rather use line voltage, 110 VAC, than batteries), and the device/component that will generate the steady stream of static/hiss.
Yes, there are products on the market which purport to provide white noise, but (and, via the Amazon reviews) their reliability is suspect, or worse (not to mention the exorbitant price demanded).
Any help provided towards the completion of this unit is gratefully received.
thank you!
Wendy
Joined Mar 24, 2008
23,429
Welcome to AAC!
I found this thread moderated. I have approved it. It is a frequent problem for new posters (as in 1st time).
Papabravo
Joined Feb 24, 2006
21,227
Some terminology may be helpful. White noise consists of equal amounts of energy at all frequencies. This is actually unachievable in reality since we can't make a real device that goes to infinite frequency. Pink noise is similar except that the frequencies are bounded on the high end and possibly the low end as well. This is realizable.
Since the upper range of human hearing is approximately 20 kz, this would be a good starting point for an upper bound. An audio amplifier with the gain (volume control turned up high enough and no input source will be a rough approximation of what you want. You should be able to buy one of these at Radio shack for small change.
Kermit2
Joined Feb 5, 2010
4,162
an analogue TV (remember them?) tuned to an empty/unused channel will also give a very loud pink noise output. Try recording that and play back on an endless loop.
Might be hard to find an empty channel these days, what, with the likes of Knife shopping networks and laser hair removal ads two hours long. :)
Papabravo
Joined Feb 24, 2006
21,227
Don't forget the ads for enhancing the pieces parts you don't even have -- ROFLMAO
kubeek
Joined Sep 20, 2005
5,795
Last time I saw a schematic of a noise generator, it used the B-C junction of a transistor in reverse breakdown mode, and then some amplification and filtering.
