electronics project idea
Discussion in 'The Projects Forum' started by abdullah8391, Oct 14, 2015.
  1. abdullah8391
    Sep 6, 2015
    53
    hi guyz!
    i need some basic electronics project ideas that
    1. should be innovative
    2. not too expensive(i.e within $100 range)
    and i want them urgently because i have to submit the proposal of project within 13 hours..
    so please any good ideas???
  2. paridhi
    Oct 15, 2015
    Make 9 Way clap home automation. its very simple but lengthy circuit.
  3. business_kid
    Feb 5, 2013
    22
    Electronics hardware? Programming? State your level of study (Beginner - Engineer)
    Doing something simple well is rewarding. unfortunately you usually have to jump through so many hoops it's hardly worthwhile. An optical tranceiver for POF.? Zigbee projects are good
  4. abdullah8391
    Sep 6, 2015
    53
    electronics hardware + beginners
    I am not working for final year project, i am searching for a small project given to us as semester project and that could be completed in a week.
  5. TheButtonThief
    Feb 26, 2011
    219
    38
    Power inverter for a small wind generator?
  6. Bernard
    Aug 7, 2008
    4,240
    414
    Everyone likes LED's; here's one suggested by jcaauwe, " Lightning Clouds", 7-10-12. LED's were embedded in fluffed up cotton.
    Here 3 LED's are imbedded in cotton in a pint brandy bottle which give a semi random double flash pattern.
    4 ea. 4014 shift registers, 4060 counter, 4011 NAND, 74AC14 not gates- note capable of driving +- 25 mA.
    Parallel inputs are hard wired hand programmed to give a pleasing pattern? White Lightning 00000.jpg
    Sinus23 and Roderick Young like this.
  7. KMoffett
    Dec 19, 2007
    2,584
    234
    I think we are too late! The OP said they only had 13 hours, and that was two day ago. :(
    Ken
  8. abdullah8391
    Sep 6, 2015
    53
    i said to submit proposal, secondly the date is extended to 19...
    so plz anything new????
  9. abdullah8391
    Sep 6, 2015
    53
    can you please explain it???
  10. KMoffett
    Dec 19, 2007
    2,584
    234
    Since you stated you are a beginner, you're probably not intending to "design" you own circuit, but build and explain the operation of something you can get off of the internet.
    Google: FYP final year project electronics
    Often there are simple ones out there. So simple in fact that I can't believe they're Final Year Projects. ;)
    Ken
  11. dl324
    Distinguished Member
    Mar 30, 2015
    3,377
    651
    Your grammar and punctuation are poor. Don't try to be cute; just put the 's' in guys and use proper capitalization to make your post easier to read.
    Innovative and basic; seems to be oxymoronic...
    A pet project of mine: sensing passing vehicles and measuring the elapsed time between two points; without using pneumatic, ultrasonic, or visible light sensors.
  12. TheButtonThief
    Feb 26, 2011
    219
    38
    A power inverter basically changes low voltage DC to a higher voltage AC, most commonly 12VDC to 110/230VAC
    A square wave inverter or even modified square wave inverter should be easy enough to make, plenty of schematic diagrams on the internet with an explanation of how the circuit works, you just need to google "square wave power inverter circuit". If it's for an assignment though, I don't suggest you simply copy and paste what you find.
    A sign wave inverter is the project grail but incredibly hard to design.
