what I need is a programmable chip, which sends out digital pules (on,off), so as to allow me to create a random die display, the reason I need to know is because if I simply try to connect the decoded decade to the display, wire run over each other and cancel each other out, where as if I had a programmable chip, when say, a current is put though pin 1, a current is put though the output of pin 2 and 3 to make a 1 on the display
